Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
DigiTech RP70 LED Light Replacement
Qué necesitas
    1. DigiTech RP70  LED Light Replacement, Motherboard: paso 1, imagen 1 de 2 DigiTech RP70  LED Light Replacement, Motherboard: paso 1, imagen 2 de 2
      • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
      • Remove the four 8mm Phillips #0 screws located on the back panel.
      Pregunta a FixBot
      Agregar Comentario
    2. DigiTech RP70  LED Light Replacement: paso 2, imagen 1 de 2 DigiTech RP70  LED Light Replacement: paso 2, imagen 2 de 2
      • Remove the back panel to expose the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    3. DigiTech RP70  LED Light Replacement: paso 3, imagen 1 de 1
      • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    4. DigiTech RP70  LED Light Replacement: paso 4, imagen 1 de 1
      • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
      Pregunta a FixBot
      Agregar Comentario
    1. DigiTech RP70  LED Light Replacement, LED Light: paso 5, imagen 1 de 1
      • Desolder the back of the motherboard where the LED light is located.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 564
