Saltar al contenido principal
Dell XPS 13 9300 Lower Case Replacement
Qué necesitas
  1. Dell XPS 13 9300 Lower Case Replacement, Unfasten the lower case: paso 1, imagen 1 de 2 Dell XPS 13 9300 Lower Case Replacement, Unfasten the lower case: paso 1, imagen 2 de 2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9300 Lower Case Replacement, Insert an opening pick: paso 2, imagen 1 de 2 Dell XPS 13 9300 Lower Case Replacement, Insert an opening pick: paso 2, imagen 2 de 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9300 Lower Case Replacement, Release the case's front clips: paso 3, imagen 1 de 2 Dell XPS 13 9300 Lower Case Replacement, Release the case's front clips: paso 3, imagen 2 de 2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9300 Lower Case Replacement, Release the remaining clips: paso 4, imagen 1 de 3 Dell XPS 13 9300 Lower Case Replacement, Release the remaining clips: paso 4, imagen 2 de 3 Dell XPS 13 9300 Lower Case Replacement, Release the remaining clips: paso 4, imagen 3 de 3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9300 Lower Case Replacement: paso 5, imagen 1 de 3 Dell XPS 13 9300 Lower Case Replacement: paso 5, imagen 2 de 3 Dell XPS 13 9300 Lower Case Replacement: paso 5, imagen 3 de 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Conclusión
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
Spencer Day
Miembro Desde 09/14/22
95,960 Reputación
662 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,648 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 23
Todo El Tiempo: 968
