Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Dell VRC100-R Battery Replacement
    1. Dell VRC100-R Battery Replacement, Battery: paso 1, imagen 1 de 3 Dell VRC100-R Battery Replacement, Battery: paso 1, imagen 2 de 3 Dell VRC100-R Battery Replacement, Battery: paso 1, imagen 3 de 3
      • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
      • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
      • Slide the cover off and separate it from the controller.
      Pregunta a FixBot
      Agregar Comentario
    2. Dell VRC100-R Battery Replacement: paso 2, imagen 1 de 2 Dell VRC100-R Battery Replacement: paso 2, imagen 2 de 2
      • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
      • Repeat the procedure for the left battery.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Kenneth Liu
Miembro Desde 04/18/18
169 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S18-G3, Livingston Spring 2018 Miembro de Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
Miembros de 4
35 Guías creadas
1Guía Comentario
Hi,
I will like to know if using 1.2V ni-mh rechargeable batteries will affect the performance of the device, as it’s been a debate for long and will appreciate your technical point of view.
Many thanks.
Baba Nam Kevalam - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 9
Ultimos 30 días: 36
Todo El Tiempo: 1,216
