Saltar al contenido principal
Dell Precision 5520 Battery Replacement
Qué necesitas
  1. Dell Precision 5520 Battery Replacement, Base Cover: paso 1, imagen 1 de 2 Dell Precision 5520 Battery Replacement, Base Cover: paso 1, imagen 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
  2. Dell Precision 5520 Battery Replacement, Battery: paso 2, imagen 1 de 1
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
Conclusión
10 personas más completaron esta guía.
Johnathan Hammond
Miembro Desde 02/28/18
45,237 Reputación
408 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
Miembros de 43
1,985 Guías creadas
2Guía Comentarios
Great directions. Simple, yet precise. Took less than five minutes.
Sam Kamara - Contestar
Easy peasy. Great instruction, exact parts with exact tools. Great price. Thanks IFIXIT!
Jason W Wines - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 26
Ultimos 30 días: 141
Todo El Tiempo: 13,639
