Saltar al contenido principal
Dell Inspiron 15-7547 Battery Replacement
Qué necesitas
  1. Dell Inspiron 15-7547 Battery Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Battery Replacement: paso 2, imagen 1 de 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Battery Replacement, Battery: paso 3, imagen 1 de 2 Dell Inspiron 15-7547 Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Battery Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15-7547 Battery Replacement: paso 4, imagen 2 de 2
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Battery Replacement: paso 5, imagen 1 de 3 Dell Inspiron 15-7547 Battery Replacement: paso 5, imagen 2 de 3 Dell Inspiron 15-7547 Battery Replacement: paso 5, imagen 3 de 3
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 24
Todo El Tiempo: 2,089
