Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Disconnect the battery using the pull tab to pull towards the front of the chassis. Most of the cable is attached to the case with adhesive, which may cause slight resistance. Most of the cable is attached to the case with adhesive, which may cause slight resistance.
  • Disconnect the battery using the pull tab to pull towards the front of the chassis.
  • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
Insertar traducción aquí
