Saltar al contenido principal
Dell Inspiron 15 5577 Gaming Battery Replacement
Qué necesitas
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Unscrew the back cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 15 5577 Gaming Battery Replacement: paso 2, imagen 1 de 1
    • Remove the back cover using an opening tool.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement: paso 3, imagen 1 de 2 Dell Inspiron 15 5577 Gaming Battery Replacement: paso 3, imagen 2 de 2
    • Use a T8 Torx driver to remove the five screws around the battery.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement: paso 4, imagen 1 de 1
    • Remove the Battery Cable by gently tugging it perpendicular from the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement: paso 5, imagen 1 de 1
    • Pull the battery out of the laptop by prying it away from the laptop. If you're having difficulty removing it, you can also use a plastic opening tool.
Conclusión
Una persona más ha completado esta guía.
[deleted]
Miembro Desde 10/31/19
346 Reputación
2 Guías creadas
Un comentario
Thank you, you guys rock
Random User - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 67
Todo El Tiempo: 5,277
