Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
DYMO LabelPOINT 100 Keypad Replacement
Qué necesitas
    1. Pregunta a FixBot
      Agregar Comentario
    2. DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: paso 2, imagen 1 de 2 DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: paso 2, imagen 2 de 2
      • Use Phillips #00 Screwdriver to remove the three screws that hold the upper portion of the access panel.
      • Remove the blade cutter assembly.
      • Use Phillips #00 Screwdriver to remove the last two screws located in the battery panel that holds the bottom portion of the access panel.
      Pregunta a FixBot
      Agregar Comentario
    3. DYMO LabelPOINT 100 Keypad Replacement, Remove Access Panel: paso 3, imagen 1 de 1
      • Gently remove the access panel from the right side of the device.
      • Some electrical wiring will be exposed and will not detach. Be careful not to damage any electrical wiring when removing access panel.
      Pregunta a FixBot
      Agregar Comentario
    4. DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: paso 4, imagen 1 de 2 DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: paso 4, imagen 2 de 2
      • Use Phillips #00 Screwdriver to remove three screws that hold down the circuit board.
      • Gently lift the bottom of the circuit board, revealing the keypad.
      • Be careful not to damage any components on the circuit board when disassembling.
      Pregunta a FixBot
      Agregar Comentario
    5. DYMO LabelPOINT 100 Keypad Replacement, Remove Keypad: paso 5, imagen 1 de 1
      • Remove the keypad from the front facing cover
      • When installing the new keypad, make sure all buttons are correctly set in each hole so that each button can be pressed.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Mike Dam
Miembro Desde 09/25/14
201 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-2, Mcgee Fall 2014 Miembro de USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
Miembros de 4
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 25
Todo El Tiempo: 1,542
