Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
DKnight MagicBox II Motherboard Replacement
Qué necesitas
    1. DKnight MagicBox II Motherboard  Replacement, Front Panel Assembly: paso 1, imagen 1 de 2 DKnight MagicBox II Motherboard  Replacement, Front Panel Assembly: paso 1, imagen 2 de 2
      • Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
      Pregunta a FixBot
      Agregar Comentario
    2. DKnight MagicBox II Motherboard  Replacement: paso 2, imagen 1 de 3 DKnight MagicBox II Motherboard  Replacement: paso 2, imagen 2 de 3 DKnight MagicBox II Motherboard  Replacement: paso 2, imagen 3 de 3
      • There are four prongs on the grill in the corners, closest to the power button switch. Use the plastic opening tool to release all four prongs from the panel, and then slide the plastic opening tool along the edge of the grill to allow it to easily slide off.
      Pregunta a FixBot
      Agregar Comentario
    3. DKnight MagicBox II Motherboard  Replacement: paso 3, imagen 1 de 2 DKnight MagicBox II Motherboard  Replacement: paso 3, imagen 2 de 2
      • On the back panel (Opposite to the side containing the two speakers), Use the Philips head PH1 to remove all 7 screws (Screws: Head PH1 , Length 7cm).
      Pregunta a FixBot
      Agregar Comentario
    4. DKnight MagicBox II Motherboard  Replacement: paso 4, imagen 1 de 2 DKnight MagicBox II Motherboard  Replacement: paso 4, imagen 2 de 2
      • Pull apart the two faces to separate the back panel from the front face plate.
      Pregunta a FixBot
      Agregar Comentario
    1. DKnight MagicBox II Motherboard  Replacement, Motherboard: paso 5, imagen 1 de 2 DKnight MagicBox II Motherboard  Replacement, Motherboard: paso 5, imagen 2 de 2
      • Remove the single screw holding the motherboard to the front panel (Screw : Head PH1, Size .5 cm)
      Pregunta a FixBot
      Agregar Comentario
    2. DKnight MagicBox II Motherboard  Replacement: paso 6, imagen 1 de 1
      • Using your fingers gently pry the motherboard loose from the black insulant adhesive
      Pregunta a FixBot
      Agregar Comentario
    3. DKnight MagicBox II Motherboard  Replacement: paso 7, imagen 1 de 1
      • Disconnect the Button Panel plug (Largest of the Plugs, it can be traced back to the button panel easily)
      Pregunta a FixBot
      Agregar Comentario
    4. DKnight MagicBox II Motherboard  Replacement: paso 8, imagen 1 de 1
      Herramienta utilizada en este paso:
      • Use the tweezers to push down on the safety prongs on the plastic switch. Then Disconnect the Power Wire plug by hand (Red medium),
      Pregunta a FixBot
      Agregar Comentario
    5. DKnight MagicBox II Motherboard  Replacement: paso 9, imagen 1 de 1
      • Use the tweezers to push down on the two safety prongs on the plastic switch. Then Disconnect the two Speaker plug connections by hand (Two Smaller Plugs)
      Pregunta a FixBot
      Agregar Comentario
    6. DKnight MagicBox II Motherboard  Replacement: paso 10, imagen 1 de 2 DKnight MagicBox II Motherboard  Replacement: paso 10, imagen 2 de 2
      • The Motherboard is now free from the speaker assembly
      Pregunta a FixBot
      Agregar Comentario
Conclusión
10 personas más completaron esta guía.
Anthony
Miembro Desde 02/04/16
704 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 17-1, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G1
Miembros de 4
6 Guías creadas
21Guía Comentarios
Where can I buy a replacement DKnight MagicBox II Motherboard ?
Francis Garvey - Contestar Compartir
My Charge Port is not working, do I need to replace the Motherboard or is there a fix for the charge port? Verified that the cable is good. It use to work if I wiggled and applied pressure to one side. Verified port is clean.
Michael Stills - Contestar Compartir
Where do you get the replacement motherboard?!
Tracie Yang - Contestar Compartir
I did the steps and the power still won't turn on. The blue light will turn on for a blink then nothing
rachelharris0528 - Contestar Compartir
mine is doing same thing. DKnight said they wont do anything because i bought it off Ebay and not Amazon.
Peter Tavella - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 34
Todo El Tiempo: 14,403
