Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
CyberPowerPC RGB 7 Color LED Backlight Replacement
Qué necesitas
  1. CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: paso 1, imagen 1 de 2 CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: paso 1, imagen 2 de 2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
    Pregunta a FixBot
    Agregar Comentario
  2. CyberPowerPC RGB 7 Color LED Backlight Replacement: paso 2, imagen 1 de 2 CyberPowerPC RGB 7 Color LED Backlight Replacement: paso 2, imagen 2 de 2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
    Pregunta a FixBot
    Agregar Comentario
  3. CyberPowerPC RGB 7 Color LED Backlight Replacement: paso 3, imagen 1 de 1
    • Lift up and remove the plastic casing.
    Pregunta a FixBot
    Agregar Comentario
  4. CyberPowerPC RGB 7 Color LED Backlight Replacement, LED Backlight: paso 4, imagen 1 de 1
    • Remove the metal backing located directly underneath the white plastic casing.
    Pregunta a FixBot
    Agregar Comentario
  5. CyberPowerPC RGB 7 Color LED Backlight Replacement: paso 5, imagen 1 de 1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  6. CyberPowerPC RGB 7 Color LED Backlight Replacement: paso 6, imagen 1 de 1
    • Carefully remove the LED board, which should now come free from the casing.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Braydon Lantz
Miembro Desde 02/12/18
229 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S15-G2, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 51
Todo El Tiempo: 1,555
