Saltar al contenido principal
Core Assembly Removal
Qué necesitas
  1. Core Assembly Removal, Power down your watch: paso 1, imagen 1 de 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Core Assembly Removal, Unscrew the back cover: paso 2, imagen 1 de 1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
  3. Core Assembly Removal, Pry open the back cover: paso 3, imagen 1 de 2 Core Assembly Removal, Pry open the back cover: paso 3, imagen 2 de 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Core Assembly Removal, Disconnect the sensor flex cable: paso 4, imagen 1 de 2 Core Assembly Removal, Disconnect the sensor flex cable: paso 4, imagen 2 de 2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Core Assembly Removal, Remove the back cover: paso 5, imagen 1 de 1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Core Assembly Removal, Disconnect the hall sensor flex cable: paso 6, imagen 1 de 2 Core Assembly Removal, Disconnect the hall sensor flex cable: paso 6, imagen 2 de 2
    • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
  7. Core Assembly Removal, Disconnect the display flex cable: paso 7, imagen 1 de 2 Core Assembly Removal, Disconnect the display flex cable: paso 7, imagen 2 de 2
    • Use a spudger to disconnect the display flex cable.
  8. Core Assembly Removal, Disconnect the side buttons: paso 8, imagen 1 de 2 Core Assembly Removal, Disconnect the side buttons: paso 8, imagen 2 de 2
    • Use a spudger to disconnect the crown button flex cable.
  9. Core Assembly Removal, Unscrew the motherboard: paso 9, imagen 1 de 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  10. Core Assembly Removal, Remove the motherboard: paso 10, imagen 1 de 3 Core Assembly Removal, Remove the motherboard: paso 10, imagen 2 de 3 Core Assembly Removal, Remove the motherboard: paso 10, imagen 3 de 3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
  11. Core Assembly Removal, Lift the core assembly: paso 11, imagen 1 de 3 Core Assembly Removal, Lift the core assembly: paso 11, imagen 2 de 3 Core Assembly Removal, Lift the core assembly: paso 11, imagen 3 de 3
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
  12. Core Assembly Removal, Release the core assembly: paso 12, imagen 1 de 2 Core Assembly Removal, Release the core assembly: paso 12, imagen 2 de 2
    • Thread the display flex cable through the opening in the core assembly.
  13. Core Assembly Removal, Remove the core assembly: paso 13, imagen 1 de 1
    • Remove the core assembly.
Conclusión
If possible, turn on your device and test your repair before installing new adhesive and resealing.
2 personas más completaron esta guía.
Adriana Zwink
Miembro Desde 12/18/19
56,528 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,537 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 20
Todo El Tiempo: 1,046
