Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
ClickN Kids Tablet Camera Replacement
Qué necesitas
    1. ClickN Kids Tablet Camera Replacement, Camera: paso 1, imagen 1 de 1
      • Start on the side with the camera
      • Insert a plastic opening tool into the space between the screen and the back side.
      • The screen side is black, the back side is colored
      Pregunta a FixBot
      Agregar Comentario
    2. ClickN Kids Tablet Camera Replacement: paso 2, imagen 1 de 1
      • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
      • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
      • The corners can be tricky. Make sure to separate the pieces all the way around the tablet before attempting to open it.
      Pregunta a FixBot
      Agregar Comentario
    3. ClickN Kids Tablet Camera Replacement: paso 3, imagen 1 de 1
      • Lift the detached screen from the camera side until you can see the inside of the tablet.
      • Don't open too fast, or you might damage the ribbons cables.
      Pregunta a FixBot
      Agregar Comentario
    4. ClickN Kids Tablet Camera Replacement: paso 4, imagen 1 de 2 ClickN Kids Tablet Camera Replacement: paso 4, imagen 2 de 2
      • Be careful not to damage any wires or ribbon cables during this step.
      • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
      • There is a black tab behind the long ribbon cable. Lift up the black tab.
      • For the ribbon cable in the back, pull the black tabs on the side out.
      • Detach the ribbon cables connecting the screen to the motherboard.
      • Remove any tape that is holding down the ribbon cables. Set it aside.
      Pregunta a FixBot
      Agregar Comentario
    5. ClickN Kids Tablet Camera Replacement: paso 5, imagen 1 de 1
      • Pull off the tape that holds the ribbon cable to the battery.
      Pregunta a FixBot
      Agregar Comentario
    6. ClickN Kids Tablet Camera Replacement: paso 6, imagen 1 de 2 ClickN Kids Tablet Camera Replacement: paso 6, imagen 2 de 2
      • Be careful not to damage the wires or ribbon cables.
      • Pull out the two black ends of the base on the motherboard.
      • Slide out the camera’s ribbon cable once the ends are loosened.
      Pregunta a FixBot
      Agregar Comentario
    7. ClickN Kids Tablet Camera Replacement: paso 7, imagen 1 de 3 ClickN Kids Tablet Camera Replacement: paso 7, imagen 2 de 3 ClickN Kids Tablet Camera Replacement: paso 7, imagen 3 de 3
      • Use a plastic opening tool to pry the camera out of its place.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Kevin Finney
Miembro Desde 03/22/15
562 Reputación
4 Guías creadas
Equipo
Baylor, Team 4-4, Williams Spring 2015 Miembro de Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
Miembros de 3
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 35
Todo El Tiempo: 1,171
