Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Qué necesitas
    1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Position Device: paso 1, imagen 1 de 1
      • Place the meter face down, and the back panel and screws can be seen.
      Pregunta a FixBot
      Agregar Comentario
    2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: paso 2, imagen 1 de 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: paso 2, imagen 2 de 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    3. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel: paso 3, imagen 1 de 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Pregunta a FixBot
      Agregar Comentario
    4. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: paso 4, imagen 1 de 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: paso 4, imagen 2 de 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Pregunta a FixBot
      Agregar Comentario
    5. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Motherboard: paso 5, imagen 1 de 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Pregunta a FixBot
      Agregar Comentario
    1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Locate Screen: paso 6, imagen 1 de 1
      • The screen is located at the top of the device.
      Pregunta a FixBot
      Agregar Comentario
    2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Screen: paso 7, imagen 1 de 1
      • Carefully remove screen from device by lifting upward.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Anna Kihm
Miembro Desde 10/13/14
965 Reputación
5 Guías creadas
Equipo
Clemson, Team 2-4, Benson Fall 2014 Miembro de Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
Miembros de 4
18 Guías creadas
1Guía Comentario
my multimeter display is broken, where can i buy a new one?
allwynrajkumar - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 33
Todo El Tiempo: 3,097
