Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Cen-Tech Seven Function Digital Multimeter Battery Replacement
Qué necesitas
    1. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Position Device: paso 1, imagen 1 de 1
      • Place the meter face down, and the back panel and screws can be seen.
      Pregunta a FixBot
      Agregar Comentario
    2. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel Screws: paso 2, imagen 1 de 2 Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel Screws: paso 2, imagen 2 de 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    3. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel: paso 3, imagen 1 de 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Pregunta a FixBot
      Agregar Comentario
    4. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Unscrew Motherboard: paso 4, imagen 1 de 2 Cen-Tech Seven Function Digital Multimeter Battery Replacement, Unscrew Motherboard: paso 4, imagen 2 de 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Pregunta a FixBot
      Agregar Comentario
    5. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Motherboard: paso 5, imagen 1 de 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Pregunta a FixBot
      Agregar Comentario
    1. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Locate Battery Attachment: paso 6, imagen 1 de 1
      • After removing the outer casing and motherboard of the device, locate the attachment site of the battery to the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    2. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Battery: paso 7, imagen 1 de 1
      • Unsnap the battery from its attachment plate.
      • When replacing the battery with a new one, be sure to properly align battery heads (positive and negative) with snaps. The positive battery head should be connected to the negative wire, and vice versa.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Anna Kihm
Miembro Desde 10/13/14
965 Reputación
5 Guías creadas
Equipo
Clemson, Team 2-4, Benson Fall 2014 Miembro de Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
Miembros de 4
18 Guías creadas
6Guía Comentarios
My case was glued or welded together. I thought it was going to break elsewhere first
No need to remove the board. Just use a screwdriver to pop the battery connector off
Osman Vincent - Contestar Compartir
In at least some of these meters, the caution label has been applied upside-down, so that it covers the screw holes.
dan - Contestar Compartir
The top of the panel has two tabs engaged (can be seen by carefully examining photos above). After screws are freed, lift the bottom edge first to allow tabs to disengage. Also, routing of battery clip wires is critical; take care that they clear the case edges.
Can't get 2nd screw out!!
KARIN SPURLING - Contestar Compartir
I had a spring in mine, and when my grandson took it apart to change battery, I don’t know where the spring came out
Rodney Grainger - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 111
Todo El Tiempo: 16,385
