Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Cable set up
  1. Cable set up, Cable set up: paso 1, imagen 1 de 1
    • Check that the red RCA plug is connected to the red RCA jack labeled "R" (this indicates the Right speaker).
    • Check that the white RCA plug is connected to the white RCA jack labeled "L" (this indicates the Left speaker).
    • To connect the ground clip, loosen the ground screw and insert the clip. Once clip is secure tighten the screw.
    Pregunta a FixBot
    Agregar Comentario
  2. Cable set up: paso 2, imagen 1 de 1
    • Check the voltage selector switch to make sure its set to the proper voltage depending on your geographic location.
    • Voltage selector should be set to 115 V/60 Hz in the U.S., or 230 V/50 Hz in other countries.
    Pregunta a FixBot
    Agregar Comentario
  3. Cable set up: paso 3, imagen 1 de 1
    • Insert power cable into socket.
    Pregunta a FixBot
    Agregar Comentario
Linea de Meta
Nikolai
Miembro Desde 10/12/11
281 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-14, Regan Fall 2011 Miembro de Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
Miembros de 4
11 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 25
Todo El Tiempo: 1,262
