Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Braun multipractic K 3000 Replacing the driver on the universal bowl
Qué necesitas
  1. Braun multipractic K 3000 Replacing the driver on the universal bowl, Lower  coupler: paso 1, imagen 1 de 2 Braun multipractic K 3000 Replacing the driver on the universal bowl, Lower  coupler: paso 1, imagen 2 de 2
    • Turn the universal bowl over so that the base is facing upwards.
    • The crack in the coupler is clearly visible. The coupler is therefore slipping in the bowl.
  2. Braun multipractic K 3000 Replacing the driver on the universal bowl: paso 2, imagen 1 de 1
    • Carefully lift the coupler off the axle using a strong flat-blade screwdriver. Reposition it several times so that it does not jam.
  3. Braun multipractic K 3000 Replacing the driver on the universal bowl: paso 3, imagen 1 de 2 Braun multipractic K 3000 Replacing the driver on the universal bowl: paso 3, imagen 2 de 2
    • Here you can see the axle and the coupler.
  4. Braun multipractic K 3000 Replacing the driver on the universal bowl: paso 4, imagen 1 de 3 Braun multipractic K 3000 Replacing the driver on the universal bowl: paso 4, imagen 2 de 3 Braun multipractic K 3000 Replacing the driver on the universal bowl: paso 4, imagen 3 de 3
    • Create a new lower coupler with the 3D printer. Print out the two press-fit tools (Picture 2) at the same time.
    • The new coupler has fewer slots, but works just as well.
    • Lightly grease the axle with food-safe silicone grease and push it in.
    • Pay attention to the washers: first the smaller metal washer at the top, followed by the black plastic washer and then the slightly larger plastic washer. At the bottom, only the metal washer rests on the coupler.
    • Fit the new coupler.
    • Place the two press-fit tools (or a suitable piece of wood) on the top and bottom and press the driver tight with a screw clamp. It must still have a very slight amount of play so that the shaft can still rotate easily.
  5. Braun multipractic K 3000 Replacing the driver on the universal bowl, Replace upper coupler: paso 5, imagen 1 de 3 Braun multipractic K 3000 Replacing the driver on the universal bowl, Replace upper coupler: paso 5, imagen 2 de 3 Braun multipractic K 3000 Replacing the driver on the universal bowl, Replace upper coupler: paso 5, imagen 3 de 3
  6. Braun multipractic K 3000 Replacing the driver on the universal bowl: paso 6, imagen 1 de 3 Braun multipractic K 3000 Replacing the driver on the universal bowl: paso 6, imagen 2 de 3 Braun multipractic K 3000 Replacing the driver on the universal bowl: paso 6, imagen 3 de 3
    • You will also need the two press-fit tools from the file for the lower coupler.
    • Place the lower driver with the shaft on the short press-fit tool. A metal washer sits on the coupler between it and the mixing bowl. Lightly grease the shaft with food-safe grease and insert everything into the mixing bowl.
    • Place the flat plastic washer, the black plastic washer and the metal washer on the upper end of the shaft. Then fit the new driver and the long press-fit tool. Press the new driver in a few millimeters with a little force, possibly also very carefully with small hammer blows.
    • Place the screw clamp on the coupler and press in the coupler. It must still have a very slight amount of play so that the shaft can still rotate easily.
Conclusión
Work through the steps in reverse order to reassemble your device.
2 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
VauWeh
Miembro Desde 10/19/15
321,196 Reputación
309 Guías creadas
Equipo
Repair is War on Entropy Miembro de Repair is War on Entropy
Community
Miembros de 36
1,615 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 29
Ultimos 30 días: 87
Todo El Tiempo: 2,461
