Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Azpen A720 Battery Replacement
Qué necesitas
  1. Azpen A720 Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Azpen A720 Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
    Pregunta a FixBot
    Agregar Comentario
  2. Azpen A720 Battery Replacement: paso 2, imagen 1 de 3 Azpen A720 Battery Replacement: paso 2, imagen 2 de 3 Azpen A720 Battery Replacement: paso 2, imagen 3 de 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
    Pregunta a FixBot
    Agregar Comentario
  3. Azpen A720 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the rear casing.
    Pregunta a FixBot
    Agregar Comentario
  4. Azpen A720 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Locate the batteries' connection points.
    Pregunta a FixBot
    Agregar Comentario
  5. Azpen A720 Battery Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    • A soldering iron can reach 600˚ F, which will cause serious burns. Learn how to solder properly here. Using tweezers to hold the wires will reduce the risk of burns.
    • Use a soldering iron to melt the connections which attach the battery to the motherboard.
    • Disconnect the red and black wires from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  6. Azpen A720 Battery Replacement: paso 6, imagen 1 de 2 Azpen A720 Battery Replacement: paso 6, imagen 2 de 2
    • Peel the black sticker off the battery to disconnect the wifi antennae.
    Pregunta a FixBot
    Agregar Comentario
  7. Azpen A720 Battery Replacement: paso 7, imagen 1 de 3 Azpen A720 Battery Replacement: paso 7, imagen 2 de 3 Azpen A720 Battery Replacement: paso 7, imagen 3 de 3
    • Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
    • When the spudger is underneath the battery avoid prying. A prying motion could damage the battery.
    Pregunta a FixBot
    Agregar Comentario
  8. Azpen A720 Battery Replacement: paso 8, imagen 1 de 2 Azpen A720 Battery Replacement: paso 8, imagen 2 de 2
    • Remove the old battery and replace it with the new battery.
    Pregunta a FixBot
    Agregar Comentario
Linea de Meta
Una persona más ha completado esta guía.
Ben
Miembro Desde 03/18/15
280 Reputación
2 Guías creadas
Equipo
Michigan Tech, Team 1-3, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-3, Lauer Spring 2015
MTU-LAUER-S15S1G3
Miembros de 2
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 2,614
