Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
August Smart Lock Accelerometer Replacement
Qué necesitas
  1. August Smart Lock Accelerometer Replacement, Accelerometer: paso 1, imagen 1 de 3 August Smart Lock Accelerometer Replacement, Accelerometer: paso 1, imagen 2 de 3 August Smart Lock Accelerometer Replacement, Accelerometer: paso 1, imagen 3 de 3
    • Flip device over so the black bottom is facing you.
    • Undo latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  2. August Smart Lock Accelerometer Replacement: paso 2, imagen 1 de 3 August Smart Lock Accelerometer Replacement: paso 2, imagen 2 de 3 August Smart Lock Accelerometer Replacement: paso 2, imagen 3 de 3
    • Grab the gears and lift them up to remove from the device
    Pregunta a FixBot
    Agregar Comentario
  3. August Smart Lock Accelerometer Replacement: paso 3, imagen 1 de 3 August Smart Lock Accelerometer Replacement: paso 3, imagen 2 de 3 August Smart Lock Accelerometer Replacement: paso 3, imagen 3 de 3
    • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
    • Disconnect the speaker plug from the motherboard
    • Disconnect the battery plugs from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  4. August Smart Lock Accelerometer Replacement: paso 4, imagen 1 de 1
    • Once the speaker is disconnected, remove the back cover.
    • Lift up the motherboard and motor assembly out of the device.
    Pregunta a FixBot
    Agregar Comentario
  5. August Smart Lock Accelerometer Replacement: paso 5, imagen 1 de 2 August Smart Lock Accelerometer Replacement: paso 5, imagen 2 de 2
    • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
    • Lift up the black tab to remove the ribbon from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
8 personas más completaron esta guía.
William Fink
Miembro Desde 09/26/17
841 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S11-G6, Passmore Fall 2017 Miembro de USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
Miembros de 4
3 Guías creadas
7Guía Comentarios
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - Contestar Compartir
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - Contestar Compartir
Same as above…. where to locate an accelerometer??
osallabe - Contestar Compartir
Did anyone find out where to buy the part?
LBurd - Contestar Compartir
Where can I find one
Jeff Wasilewski - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 62
Todo El Tiempo: 8,845
