Saltar al contenido principal
Asus X200CA Display Replacement
Qué necesitas
  1. Asus X200CA Display Replacement, Display: paso 1, imagen 1 de 1
    • Wedge a metal spudger between the bezel and display cover.
    • Slide the metal spudger back and forth along the top, left, and right sides to pry apart the screen from the outer shell.
  2. Asus X200CA Display Replacement: paso 2, imagen 1 de 2 Asus X200CA Display Replacement: paso 2, imagen 2 de 2
    • Remove the six silver 2.7 mm screws securing the screen bracket to the screen bezel.
  3. Asus X200CA Display Replacement: paso 3, imagen 1 de 2 Asus X200CA Display Replacement: paso 3, imagen 2 de 2
    • Slice the silver foil tape with a spudger by applying pressure between the frame and the back of the screen case.
  4. Asus X200CA Display Replacement: paso 4, imagen 1 de 1
    • Pull apart the black fabric tape with your fingers.
  5. Asus X200CA Display Replacement: paso 5, imagen 1 de 2 Asus X200CA Display Replacement: paso 5, imagen 2 de 2
    • Use an opening tool to peel off the sticker label securing the LCD cable to the LCD display.
    • Gently pull the sticker to disconnect the LCD cable.
    • Potential for device damage: Do not use excessive force while removing the video cable attached to the back of the LCD.
  6. Asus X200CA Display Replacement: paso 6, imagen 1 de 1
    • Lift the LCD screen to remove it from the device.
  7. Asus X200CA Display Replacement: paso 7, imagen 1 de 3 Asus X200CA Display Replacement: paso 7, imagen 2 de 3 Asus X200CA Display Replacement: paso 7, imagen 3 de 3
    • Remove the four silver 2.7 mm screws to separate the LCD screen from the two screen brackets.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G2, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,762
