Saltar al contenido principal
Asus X200CA Battery Replacement
Qué necesitas
  1. Asus X200CA Battery Replacement, Keyboard: paso 1, imagen 1 de 2 Asus X200CA Battery Replacement, Keyboard: paso 1, imagen 2 de 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Battery Replacement: paso 2, imagen 1 de 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Battery Replacement: paso 3, imagen 1 de 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Battery Replacement, Battery: paso 4, imagen 1 de 2 Asus X200CA Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the black 4.7mm screw holding the battery in place.
  5. Asus X200CA Battery Replacement: paso 5, imagen 1 de 1
    • Lift the battery by the tab you removed the screw from.
    • Replace with the new battery, if necessary.
Conclusión
11 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G2, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
Miembros de 4
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 7,082
