Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Asus ROG Strix GL702VS LCD Screen (Display) Replacement
Qué necesitas
  1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): paso 1, imagen 1 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): paso 1, imagen 2 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): paso 1, imagen 3 de 3
    • Remove the two screw stickers at the bottom corners of the screen.
    • Remove the two 4mm JIS #0 screws beneath the stickers.
    Pregunta a FixBot
    Agregar Comentario
  2. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 2, imagen 1 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 2, imagen 2 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 2, imagen 3 de 3
    • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
    • Using an opening tool, lift up the bezel once the glue has been removed.
    • The plastic clips remain so it will have some resistance/snapping noises.
    Pregunta a FixBot
    Agregar Comentario
  3. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 3, imagen 1 de 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 3, imagen 2 de 2
    • Lift the plastic bezel off of the front display panel.
    • The plastic bezel will click when put back on the screen.
    Pregunta a FixBot
    Agregar Comentario
  4. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 4, imagen 1 de 1
    • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
    Pregunta a FixBot
    Agregar Comentario
  5. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 5, imagen 1 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 5, imagen 2 de 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 5, imagen 3 de 3
    • Once the LCD display is freed you can lift it up out of the casing.
    • Be careful as the cable remains attached.
    Pregunta a FixBot
    Agregar Comentario
  6. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 6, imagen 1 de 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
    • Once fully disconnected, remove the LCD and replace it.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 39
Todo El Tiempo: 2,326
