Introducción
Use when the USB port needs to be removed. (Soldering Required)
Qué necesitas
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Press the tip of a hot soldering iron to the USB connection to melt the solder.
Use a nylon spudger to lift the USB from the solder.
Repeat for each of the four USB connections.
2 personas más completaron esta guía.
4Guía Comentarios
something was broken out of the port of the USB connection
Will this method work with the 2015 tr mixamp?
