Saltar al contenido principal
ASUS ROG Strix GL503VD-DB71 Battery Replacement
Qué necesitas
  1. ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: paso 1, imagen 1 de 2 ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Start with flipping the laptop over so that the bottom side is facing up.
  2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: paso 2, imagen 1 de 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: paso 2, imagen 2 de 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: paso 2, imagen 3 de 3
    • Remove the screw for the small panel with a Phillips #1 screwdriver.
    • Use your plastic opening tool to lift up the cover to remove it.
    • Remove the screw beneath the service cover with a Phillips #1 screwdriver.
  3. ASUS ROG Strix GL503VD-DB71 Battery Replacement: paso 3, imagen 1 de 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: paso 3, imagen 2 de 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: paso 3, imagen 3 de 3
    • Remove the 9 screws around the perimeter of the back case with a Phillips #1 screwdriver.
    • Use a plastic opening tool to pry the back cover off of the device.
    • Remove the back cover exposing the battery.
  4. ASUS ROG Strix GL503VD-DB71 Battery Replacement: paso 4, imagen 1 de 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: paso 4, imagen 2 de 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: paso 4, imagen 3 de 3
    • Remove the single screw securing the battery with a Phillips #1 screwdriver.
    • Gently pull the battery cable from its connector on the motherboard.
    • Lift up on the battery to remove it.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 86
Todo El Tiempo: 5,096
