2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
Preguntas 939 Ver todo
Black screen, works on external
I have a MacBook Pro 15" early 2008 A1226. For a long time it had white lines on the screen which I was Ok with. (see image taken from another poster on this forum, thank you!) Then about a week ago the screen went really dim and then black. Everything runs Ok and I can use the Mac with an external monitor. I have reset the PRAM, SCM and opened it up and did a quick scan of connections. However, haven't gone so far (yet) as to open the display. I'd prefer to do that only once, so...
How do I know if this is the inverter or the LED driver board or something else without opening it up and checking or replacing the parts and cables? Is there a simple way to figure out what parts to order?
Thank you
Thank you oldturkey03! Please see attached images. If you need photos of another part, please let me know.
I have been thinking that perhaps I have two issues going on.
1: the backlight. My reasoning for this is the screen is black, mac works great with an external monitor and I can see images when I shine a light through the apple logo on the back of the laptop LED.
2: the stage light issue. Hopefully the images I have attached will help narrow this down.
Am I correct that there are two issues with the screen? I actually don't care as much about the stage lighting effect. I've had that for quite sometime. I'd really just like to have a laptop again. Right now, since I have to use an external monitor it has become a desktop. (though having the larger monitor is really nice for viewing photos) Perhaps the stage lighting and black screen are the same...
Update: I replaced the LED driver board and still have a black screen. Any other ideas?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Solución Elegida
@mp22 this is not an inverter issue. The "stage lighting" effect is most commonly caused by issues with the LED returns. Check the resistors around your LVDS connector. Also check the LED driver. For that you will of course need the logic board schematic, the boardview files and a good multimeter. So you will have to identify your logic board by its 820-XXXX number and possibly post some good images of your logicboard with your question. Use this guide Adding images to an existing question for that
Fue útil esta respuesta?
Calificación 1
Comentarios:
Wow, thank you. It may take me a bit, but I will try to figure all that out and post photos for you.
por
@mp22 give us your logic board number and just post some images. Let us help you with the rest :-)
por
Thanks. I posted an update.
por
Respuesta Más Útil
Would you give us a link to the exactly where you got that image? It sounds like your answer is on that post and this is just a "me too" question.
Calificación 1
Comentarios:
LED Back light problems..
Could be and if so my apologies... I did forget to add that shining a flashlight through the apple logo allows me to see some of the laptop screen. For a bit I thought this solved it and means it's the backlight. However, I read some other answers to similar issues on this website and for some it was the LED driver board... I can't seem to find that posting now. Perhaps that's for the best. Reading the other posts again, it seems I should try replacing the inverter.
However, if you have different thoughts, please let me know. Again, thank you and sorry for the repeat posting.
por
Añadir tu respuesta
mp22 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 3
Últimos 30 Días: 17
Todo El Tiempo: 162
