Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
Preguntas 3944 Ver todo
Flash not working after screen and battery replacement
I dropped my phone and shattered the screen in a spectacular fashion. Both cameras and the flash worked after that happened. I ordered new parts from iFixIt and replaced the screen and popped in a new battery just two days later
Now I've got no flash! Didn't realize how often I used it as a flashlight until last night when I was trying to navigate a dark house.
Opened the phone back up today and reseated all the connectors, including the rear camera, and had the LED flash working right until I put it back together, now no flash again, but cameras both work fine. Flashlight is available, just doesn't light the LED anymore.
Any ideas what may be wrong?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
I purchased a power button flex, but other issues popped up while I was waiting for time to work on it. The screen seems to have less sensitive areas than others, I thought that was due to the screen protector I added. The front camera became intermittent, then went completely out. I also noticed 2-5 lines from the top of the display showing up at the bottom. And last night the whole display became non-responsive. I'm sending it out for some help.
I'll let you know what the verdict is.
por
Hi trose95822,
I have the same problem too, after replacing my iphone 6 (no plus) screen, the flash stopped working. It does not work either in torch mode or in photo / video mode.
The rear camera works well.
When the torch button is pressed, the flash flashes for a few moments, as in this video (https://www.youtube.com/watch?v=KqxVgYUj...).
I recently replaced the flash but still have the same problem.
Did you manage to solve it??
Thanks in advance.
por
Agregar un comentario
1 Respuesta
Solución Elegida
You should try to replace the Power Button Flex; it contains the Flash. It was probably damaged by the impact of the drop.
Follow this guide.
Imagen iPhone 6 Power Button Cable and Bracket
Producto
$9.99
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
trose95822 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 13
Últimos 7 Días: 58
Últimos 30 Días: 242
Todo El Tiempo: 803
