Saltar al contenido principal
Is it possible to fix a popped out screen swivel hinge?
One end of the swivel arm holding the screen on a Panasonic portable DVD player has partially popped out. I tried to push it back in, but it does not bulge. Does anyone know whether there is a way to fix it? My kid would be very happy if we can fix it. Thank you.
Es esta una buena pregunta?
Puntuación 2
3 comentarios
Hi @happyvalley ,
Post some close up images so we can see what you can see
Here's how to add images using ifixit
Agregar imágenes a una pregunta existente
- de
Thanks a lot, Jayeff! The link to the manual was very helpful. I was able to take the sleeve off the joint, and fix it. I truly appreciate your help!
- de
Hi @happyvalley ,
You're welcome.
Glad that you got it fixed OK.
Hopefully you are now even higher in your child's estimation. ;-)
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
To me the first picture indicates that it is broken and has not just come out of its' slot.
Here is a link to the service manual for the player.
I think that the broken part is actually a fixed part of the monitor cover See part #20 that the monitor support arm (part #12) locks onto. Here is an image highlighting what I think is the piece that is broken
(click on image to enlarge for better viewing)
Searching for the monitor cover assembly (part # RFKKPDLS91AS found on p.72 -item 20 as per the drawing) gives results but none have any pictures to verify what I think.
Perhaps you may have better luck in finding out.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Will estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 494
