Why is phone not charging?
Hi there, the thing is that i have less than a month with the phone but it suddenly stopped charging. I didn't drop it and it never touched water, so I have no clue what happened. Already tried pressing all buttons, leaving it charging all night, etc. Any ideas?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Comentarios:
Have you connected the USB cable to a computer or a different charger to see if it charges?
por
Yeah I already did
por
open back cover.... open usb charge socket DO short circuit usb SOCKET AND TOUCH A WIRE OR A METAL THING BOTH SIDES BAC OF THE USB CHARGIN PLACE DO IT 2 OR THREE TIMES THEN IT WORKS..... MY TWO PHONES WORKED THE MAIN REASON WHY THEY DONT CHARGE IS USING SOME FAST CHARGING CHARGERS OR POWERBANKS...... DO WHAT I SAID IT WORKS
por
Can you explain how to shortcircuit the charging port?
por
Yes how to do the short circuit thing? Can you explain step by step
por
Mostrar 4 comentarios más
Agregar un comentario
6 Respuestas
Solución Elegida
Hi,
Use a strong light and a magnifying glass to visually inspect the USB charge port.
Check that the pins are all there and that they are straight and parallel with each other. Also verify that there is no lint or dust in the port enclosure.
If there is dust or lint, do not use a metal probe to try and remove it as you may damage the pins. Try a vacuum cleaner, using short sharp bursts to see if it removes the debris. If it is still there after trying a vacuum cleaner, then using a wooden toothpick very gently pry it out.
If there is nothing in the USB port and as your phone is less than 1 month old , I suggest that you consult the warranty section in the documentation that came with the phone as to what you have to do to make a claim for a manufacturer's warranty repair or replacement.
Fue útil esta respuesta?
Calificación 2
Comentarios:
I had same issue with my note 3, it wasn't charging normally and have to put it in a unique position to charge without disturbance.
To fix it, I just pushed the charging pin inside the phone charging socket a little upward.. Light n gentle push with a flat steel pin. And it worked, and is charging in any position I throw.
por
It worked for me..thanx..had tried software update,developer options etc but your method was the only effective one..
por
My phone is not charging quickly than as usual
por
Check if the adapter and the usb cable are working properly ( even if you use the original one. ) If they are okay, then probably the problem is lint. Try cleaning the charging port with a toothpick or paper. Try restarting the phone and charge again.
If nothing works, its best to take your phone to the service center.
Calificación 1
Comentarios:
But charger is functioning properly with other mobile ,another mobile charge properly without failing and get mobile full charge.
por
I had the same problem the solution that worked for me is to shut down the phone and charge it.
after a few days of doing that it goes back to charge normally
Calificación 0
Comentarios:
It happened to my phone too. It was dead for like almost 2 weeks. And then I let it charge whole day, it turned on just for 3 days. Now it won't charge again.... It is really killing me.
por
I try to charge my phone. But it cannot charge more than 15%..Even I charge whole night. Please suggest solution.
Calificación 0
Comentarios:
I purchased this phone 2-3month back only. I am not happy regarding this phone. Whats the Issue?
por
Hi,
My Redmi crashes on plugging the charge cable. On plugged it showed red light blinking. But when I open the case and then discount and count the internal battery port (located beside battery), it will boot again.
On blinking it will charge but i have open the case and disconnet and connect the port. What shall do.
Calificación 0
you restart the mobile
Calificación 0
Comentarios:
I had a problem with my note 3 pro showing -2% of battery...please help me
por
Añadir tu respuesta
Daniela estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 157
Últimos 7 Días: 1,022
Últimos 30 Días: 4,542
Todo El Tiempo: 58,766
