The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
Preguntas 233 Ver todo
note 4 screen not turning on but buttons still light up
After opening up my note 4 and adjusting the gps antenna on it when i put it back together the screen no longer turns on but the buttons still lights up indicating that power is running to it can you guys give me a brief idea of what component i need to check out to fix this?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
1 Respuesta
Solución Elegida
The LCD cable plugs in behind the logic board. It probably went loose if you lifted up the logic board. You simply just need to plug it back in. It's a bit tricky to do.
Fue útil esta respuesta?
Calificación 3
Comentarios:
do u have a picture of which ones?
por
Check step 6 of this guide. You should be able to plug in the two cables. I think one is for the S-Pen and the other is for the digitizer + lcd.
Samsung Galaxy Note 4 Display Assembly Replacement
por
Añadir tu respuesta
baconlover53 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 9
Últimos 7 Días: 31
Últimos 30 Días: 144
Todo El Tiempo: 2,169
