Saltar al contenido principal
El Sony Xperia Z3 es un smartphone lanzado en 2014, conocido por su larga duración de bateria y su durabilidad.
Preguntas 114 Ver todo
Can I reuse undamaged back cover?
So essentially I got a Z3 for pretty cheap (200 Euro) however the camera lens is full of dirt which makes the photos come out kind of bad. I was wondering if I could remove the back cover, clean the lens and use new back cover adhesive but keep the same glass cover?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
Absolutely! Just be careful not to damage when removing. It is adhered to the back of the phone and cracks easily. I would use plenty of heat and have plenty of patience when removing the back. I would also check ifixit for a guide, or youtube!
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thanks I'm going to go order the adhesive tonight.
- de
I would recommend replacing the entire back glass after removing it.
They are dirt cheap to buy and saves cleaning it/adding new adhesive.
You can probably buy the back glass with adhesive not much more then the actual adhesive.
Puntuación 0
Añadir tu respuesta
Hup estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 18
Todo El Tiempo: 404
