Saltar al contenido principal
Unibody de aluminio de 13", procesador Core 2 Duo de 2.0 o 2.4 GHz.
Preguntas 574 Ver todo
My mag safe does not work any more :(
for some reason my charger does not charge the mb.... it cannot power the machine... or charge the battery...
i have replaced the AC adapter brand new from mac... the plug that plugs to the power and the mac
so now i have question do you think its the internal piece? the dc adapter on the motherboard? what else can it be?
Update
well ... i just replaced this part... replaced AC adapter... what else can it be???
battery still not charging :(
Update
I replaced the DC-IN Board... still does same thing...
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios
test it out with a multimeter and trace the current from the magsafe port and work inward.
- de
If your machine has suffered some type of accident, it's best you disclose that info in order to better help you.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
This is the part that you most likely have to replace. If you hurry, iFixit has ONE in stock. Did u have an accident? Water damage? Fall?
Update
I would look into the Battery connection to the LogicBoard. You never answered my question: what happened to the Mac? what caused these symptoms??
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
+ agreed
- de
I have the same situation and I think its the logic board. Does anyone know how to fix it? In my case charger is flashing green so there must be a shortage. I am sure I could fix it, just dont know where to look.
Puntuación 0
1 comentario:
Please start your own question, you have a better chance of getting helped this way. Or if you have input or ideas, just leave a comment.
- de
well... I gave my laptop to private mac repair place... they can use my warranty to get my new logic board , I should know everything is good by wed's :)
Puntuación 0
Añadir tu respuesta
michael kos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 3,624
