A smartphone by Samsung running Android, identifiable by the model number GT-S5570, released in 2011.
Preguntas 19 Ver todo
I forgot my Galaxy Mini password, how do I reset it
As I switch my phone on, It requires a (pattern) password and I have forgotten it
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 21
Comentarios:
Did you set a pin number incase you forgot your pattern?
por
No I never set a pin number
por
wifi and bluetooth not working
por
Agregar un comentario
5 Respuestas
Solución Elegida
Hi,
If you make some wrong entries the phone will offer you to log on with your google account. But you must have WiFi connection. You can't make new connection and your WiFi must be turned on from before.
The second way is with adb commands. But for this you must have enabled USB Debugging from before. Otherwise you can't connect it with the PC.
The third way is Factory Reset but you will LOST all your data. Push and hold together vol(+) and power on keys.
With vol(-) chose Factory Reset. The power on key is for ok.
Samsung Galaxy S5 - Desbloquear Sin Contraseña
Regards.
Fue útil esta respuesta?
Calificación 5
1-code formati https://www.facebook.com/rebels.tn.3
2-conneceter sur wifi entre email et mot passe
Calificación 2
yes
Calificación 0
I tried it ten time and it said type your Google account and it said it rong
Calificación 0
omg it worked thank you and keep up the good work
Calificación 0
Añadir tu respuesta
King James estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 46
Últimos 30 Días: 218
Todo El Tiempo: 13,335
