Saltar al contenido principal
How to Alter the Waist of Jeans
Qué necesitas
  1. How to Alter the Waist of Jeans, How to Alter the Waist of Jeans: paso 1, imagen 1 de 1
    • Put on the jeans and pinch the extra fabric at the centre back of the waistband.
  2. How to Alter the Waist of Jeans: paso 2, imagen 1 de 1
    • Mark both sides of the pinched fabric with chalk on the outside of the jeans.
    • You may do this step while wearing the jeans.
  3. How to Alter the Waist of Jeans: paso 3, imagen 1 de 3 How to Alter the Waist of Jeans: paso 3, imagen 2 de 3 How to Alter the Waist of Jeans: paso 3, imagen 3 de 3
    • Draw a diagonal line from each marked spot to the centre back seam.
  4. How to Alter the Waist of Jeans: paso 4, imagen 1 de 2 How to Alter the Waist of Jeans: paso 4, imagen 2 de 2
    • Pass the thread through the loop on the needle threader.
    • Pull the needle threader out of the eye of the needle and create a knot at the end.
    • Use a double thread or a thick thread for durability.
    • For more information on using a needle threader, use the How to Use a Needle Threader Guide.
  5. How to Alter the Waist of Jeans: paso 5, imagen 1 de 2 How to Alter the Waist of Jeans: paso 5, imagen 2 de 2
    • Begin sewing from the inside out, starting beside the belt loop.
    • Bring the needle across the marked spot and sew it inside out.
  6. How to Alter the Waist of Jeans: paso 6, imagen 1 de 2 How to Alter the Waist of Jeans: paso 6, imagen 2 de 2
    • Move the needle horizontally, then insert and thread it through the fabric a short distance below the starting point.
    • Repeat this process until the thread reaches the centre back seam.
  7. How to Alter the Waist of Jeans: paso 7, imagen 1 de 3 How to Alter the Waist of Jeans: paso 7, imagen 2 de 3 How to Alter the Waist of Jeans: paso 7, imagen 3 de 3
    • Pull the thread to conceal the stitches.
  8. How to Alter the Waist of Jeans: paso 8, imagen 1 de 2 How to Alter the Waist of Jeans: paso 8, imagen 2 de 2
    • Bring the thread back to the inside of the jeans, tie a knot, and cut the excess thread.
  9. How to Alter the Waist of Jeans: paso 9, imagen 1 de 1
    • Repeat steps 4-8 on the other side.
Conclusión
Zoe Kim
Miembro Desde 09/19/23
179 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 51
Todo El Tiempo: 241
