Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
The is device not powering on when switch is engaged
The cord is not plugged in all the way or the device is not receiving power
If the grinder is not turning on, the most common issue is that it is not receiving power. To fix this, make sure the tool is powered off and completely remove the plug from the wall outlet then reconnect it. If the device still won't power on, plug something else into the socket to make sure the fuse or the outlet has not blown.
Frayed or disconnected power cable
A frayed power cable requires disassembly of the device body and then replacement, while an internally disconnected power cable requires disassembly of the tool body and then reconnection of a few screws to reattach the cable to the power sink. See the electrical cord replacement guide for further instructions.
Broken or disconnected switch
This is similar to a frayed or internally disconnected power cable. A broken or internally disconnected power switch requires disassembly of the device's body for replacement and reconnection. See the switch replacement guide for further instructions.
Sparks or Smoke when the device is being operated
Worn or broken carbon brushes
The most likely cause of sparks and/or smoke is disconnection or wearing down of the carbon brushes. The carbon brushes are two pieces of an electric motor which transmit current to the rotating armature via the commutator. When worn or broken carbon brushes interact with the communicator abnormally, they can produces sparks and/or smoke. See the carbon brush replacement guide for further instructions.
Broken armature
Often sparks and/or smoke can be caused by a broken armature. The communicator (which is part of the armature) may have been damaged or broken by the carbon brushes. Overworking the tool may also cause the armature to break by burning out the windings (the copper wires in the armature). In either case, see the armature removal guide and check for any visible damage.
Unnecessary or unusual noise during operation
Overworking the machine (lack of cool down time)
Apply less pressure to the angle grinder when grinding a surface or after working a hefty job. It is recommended to let the grinder spin freely for a couple of seconds to allow the tool to cool down. Give the angle grinder some time to cool down after any job and refrain from continued use over long periods of time.
Slow performance
Wrong kind or unbalanced disk
Because an angle grinder is a multipurpose tool, it comes with multiple wheels and disks. Make sure the correct size and type of disk is being used for the task at hand. After checking the disk, look for signs of the disk deterioration such as dull blades, chipped edges, cracks, or uneven wear.
Worn carbon brushes
If the angle grinder is not spinning at a constant speed or is slower than normal, the carbon brushes may be worn down. The carbon brushes are two pieces of an electric motor that transmit current to the rotating armature via the commutator. Worn carbon brushes can decrease the overall performance of the motor. See the carbon brush replacement guide for further instructions.
Power loss over a large amount of extension cable
Turn device off completely before unplugging it from the extension cord. Try plugging the device directly into a wall outlet to see if the performance and speed increase.
Heat coming from the body of the device
Needs more grease
An excessive amount of heat may be caused by a lack of grease in the wheel bearing. Grease is a lubricant which helps to decrease the amount of internal friction within the device. See the grease replacement guide for further instructions.
Needs to be cleaned
There may be dirt, sand, or metal bits in the grease that would create friction thus causing heat. This can be fixed by cleaning the inside of the device. See guides for replacing the armature and replacing the grease and then blow with compressed air.
7 comentarios
I have a makita angle grinder that won't work on my generator but does work on the mains. I've used several other higher wattage power tools on the genny and all work fine so cant see why the angle grinder wont . Any clues???
Alan Read - Contestar
Exactly the same problem here: small grinder GA5030R and the generator with peak 6500W. The larger grinder (2000W) and many other high wattage equipment - all work faultlessly. Perplexing….
Martin Lucas -
OK, after years of searching for answer, I finally have one!
It's because of the soft start .
AC sinus from generator is not smooth enough. To make it smoother, switch other induction type appliance to the same socket, at the same time switch on the grinder. It will work. Tried and tested. Cheers!
Martin Lucas -
Not sure what model I have but it’s a variable speed one. It recently started making a loud gurgling noise during operation (Dosent sound good). I opened it up and put in more grease in the gears (Did nothing). Any ideas of what could be wrong with it?
Michael - Contestar
I have a variable speed grinder but it only spins on the lowest speed. I have changed the brushes but speed does not increase when I turn up the dial. I have also cleaned out the inside and regreased but still no change. Any ideas please?
darren.mcneely - Contestar
