Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Garmin nuvi 2460LMT Troubleshooting
Released 2011. Identified by part number 010-00903-08
Unresponsive Screen
Your screen is not responding to input.
Device Crash
Power down the device and then power it back on. Hold the power button on the top-left-hand side of the device for five seconds, then press it again after the device has powered off. Check to see if there is any change to the responsiveness of the screen.
Update Needed
If the problem persists, there may be a problem with the software release. Search for Garmin nuvi 2460lmt and download the "Garmin Express" update software. Once installed, open "Garmin Express" on your computer and click the "Add Device" button. You will then be asked to connect your device via a USB cable. Afterward, click the device icon and then click "Install All" on the device's dashboard, where you will be guided through the process.
Defective or Broken Screen
Your device may have a defective or broken screen and needs to be replaced.
Audio Distortion
You have trouble hearing sounds from your device.
No Volume
Adjust the volume to make sure it is not muted or turned all the way down. On the "Main Menu" screen, tap the volume icon and move the slider up to hear if there is a noticeable change in audio.
Update Needed
Your device may need an update to address the audio issue. Check for updates using the provided instructions in "Update Needed" found under "Unresponsive Screen".
Faulty Speaker
Your device may have a defective speaker and needs to be replaced.
Battery Drain
Your device either drains battery too quickly or powers off when not plugged in.
Dead Battery
Attempt to recharge the battery. To recharge the device's battery, plug the device into a plugged-in computer or a wall adapter via the included USB cable and wait for at least 45 minutes. Check periodically to see if the device recharges. A full battery is indicated by a battery icon in the upper-right-hand corner of the device's display.
Update Needed
An update may be available to address this issue. Use the instructions provided in "Update Needed" under "Unresponsive Screen" to guide you through the process.
Garmin Power Failure
Your device's battery may be dead and no longer able to hold a complete charge. It will need to be replaced.
0 comentarios
