Saltar al contenido principal
Garmin nuvi 2460 LMT Speaker Replacement
Qué necesitas
  1. Garmin nuvi 2460 LMT Speaker Replacement, Back Cover: paso 1, imagen 1 de 2 Garmin nuvi 2460 LMT Speaker Replacement, Back Cover: paso 1, imagen 2 de 2
    • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
  2. Garmin nuvi 2460 LMT Speaker Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
  3. Garmin nuvi 2460 LMT Speaker Replacement: paso 3, imagen 1 de 1
    • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
  4. Garmin nuvi 2460 LMT Speaker Replacement: paso 4, imagen 1 de 1
    • Lift the connector gently from the socket, making sure you pull in the right direction.
  5. Garmin nuvi 2460 LMT Speaker Replacement, Speaker: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Lift and separate the speaker connector cable using a pair of tweezers.
  6. Garmin nuvi 2460 LMT Speaker Replacement: paso 6, imagen 1 de 1
    • Gently lift the speaker out of the back cover using a plastic opening tool.
    • Apply force as needed if there is glue holding the speaker in place.
Conclusión
Ricardo Audain
Miembro Desde 09/07/16
671 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 6-4, Remmell Fall 2016 Miembro de USF Tampa, Team 6-4, Remmell Fall 2016
USFT-REMMELL-F16S6G4
4 Miembros
7 Guías creadas
Un comentario
Where do I get the parts for the garmin nuvi 2460? I can’t find anything online or ebay. I need a speaker and a microphone replacements!
Mark Peterson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 228
