Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Battery Will Not Hold Charge
Once laptop is fully charged, the battery life is either poor or short.
Drained Battery
Overtime, the battery life in a laptop will decrease due to old age, constant use while plugged in, or not recharging/discharging it to its extremes. After many cycles, a laptop will last on battery power for only a short period of time. In order to bring your battery life back to normal, you must replace the battery pack. Follow the steps on how to replace your battery pack by clicking here.
Laptop Will Not Power On
When clicking the power button, the laptop fails to power on.
Drained Battery
If the laptop only powers when it is plugged in, then the battery life has come to an end. This is due to old age, constant use while plugged in, or not recharging/discharging it to its extremes. In order to bring your battery life back to normal, you must replace the battery pack. Follow the steps on how to replace your battery pack by clicking here.
Faulty Power Adapter
If the power indicator is not lit regardless of the laptop being plugged in or not, then the power adapter may be faulty. Try borrowing a power adapter from a friend and see if it works. If this is not possible, you may have to purchase a new power adapter.
Non-Bootable Disk Connected
If the power indicator is lit but the laptop does not power on, then a non-bootable disk may be plugged into the external USB floppy drive. Ensure to remove or replace non-bootable disk with a system disk and then press <Ctrl> + <Alt> + <Del> to reset system.
Faulty DC Port
If the power indicator is not lit regardless of the laptop being plugged in (with a working power adapter) or not, then the DC input may be faulty. In order to be able to charge your laptop correctly again, you must replace the DC input port. Follow the steps on how to replace your DC port by clicking here.
Display Unresponsive
The laptop is powered on; however, display is black or slightly dimmed.
Automatic Dimmed Display
If the display is dimmed, the laptop may have an automatic dimmed display setting turned on, or it may be on power saver mode. Check the laptop’s settings to ensure this feature is not turned on. If it still appears dimmed, check below for further troubleshooting.
Faulty Display
If the display is black or dimmed after troubleshooting, the display may likely be damaged and needs to be replaced. Follow the steps on replacing the display by clicking here.
Laptop is Overheating
Laptop begins to get extremely hot while using it.
Slots and Ports are Blocked
If the laptop begins to overheat during use, the slots and ports may be blocked and obstructed. Ensure that all openings on the laptop are not being obstructed so that the laptop’s internals can get proper ventilation. Keep laptop on a flat surface, and do not leave it resting on a pillow, bed, couch etc.
Dust in Fan
Another reason may be due to excessive dust obstructing the laptop’s fan. When this happens, the laptop does not get proper ventilation which causes overheating. To solve this, purchase a compressed air duster and spray it on the laptop’s openings, removing all dust and unnecessary gunk covering its openings.
Inadequate Amount of Thermal Paste
The connection of the CPU to the thermal module is the greyish color thermal paste which allows for proper heat transfer between metal components. It is likely that the thermal paste on the thermal module may not be providing its intended use anymore. Follow the steps on replacing the thermal paste by clicking here.
Thermal Unit Failure
If the first three methods do not solve the laptop’s overheating issues, then it may be an issue with the thermal module. The thermal module may not be connected correctly, or it needs to be replaced. Follow the steps on replacing the thermal module by clicking here.
Keyboard Not Responding
The keys on the keyboard and not responding even though laptop is powered on.
Software Disabled
Sometimes if you click a button by mistake, the operating system will disable the keyboard. In order to fix this issue, you must restart the computer. Majority of the time this will correct an unresponsive keyboard.
Faulty Driver
Another common issue with the keyboard being unresponsive has to do with the keyboard driver installed in the operating system. Sometimes the driver stops working correctly. Try reinstalling your keyboard driver.
Faulty Keyboard
If the entire keyboard does not respond after using the previous two methods, then either the wiring is not connected properly, or the keyboard needs to be replaced entirely. Follow these steps on how to disassemble the keyboard and replace it by clicking this link.
0 comentarios
