Saltar al contenido principal
Acer TravelMate P653-V-6882 Keyboard Replacement
Qué necesitas
  1. Acer TravelMate P653-V-6882 Keyboard Replacement, Battery Pack: paso 1, imagen 1 de 2 Acer TravelMate P653-V-6882 Keyboard Replacement, Battery Pack: paso 1, imagen 2 de 2
    • Turn the computer over so the base is facing up.
    • Slide the battery lock to unlock position.
  2. Acer TravelMate P653-V-6882 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the battery release latch to the right.
    • The battery pack will pop out.
  3. Acer TravelMate P653-V-6882 Keyboard Replacement: paso 3, imagen 1 de 1
    • Lift the battery up.
    • Pull out the battery.
  4. Acer TravelMate P653-V-6882 Keyboard Replacement, Base Door: paso 4, imagen 1 de 1
    • Remove the five 7mm Phillips #1 screws.
  5. Acer TravelMate P653-V-6882 Keyboard Replacement: paso 5, imagen 1 de 1
    • Use the opening tool to separate base door from the bottom of the laptop.
    • Be careful not to bend or crack the plastic back cover.
  6. Acer TravelMate P653-V-6882 Keyboard Replacement: paso 6, imagen 1 de 2 Acer TravelMate P653-V-6882 Keyboard Replacement: paso 6, imagen 2 de 2
    • Gently pry open the base door by pushing up.
    • Pull out the base door.
  7. Acer TravelMate P653-V-6882 Keyboard Replacement, Keyboard: paso 7, imagen 1 de 1
    • Remove the two 7mm Phillips #1 screws.
  8. Acer TravelMate P653-V-6882 Keyboard Replacement: paso 8, imagen 1 de 1
    • Flip the laptop so that the underside is now facing the bottom.
    • Open the LCD panel.
    • Use the flat end of a spudger to push in the six latches.
    • Be careful not to bend or crack the keyboard.
  9. Acer TravelMate P653-V-6882 Keyboard Replacement: paso 9, imagen 1 de 1
    • When the latches are pushed in, the keyboard will pop out.
    • Gently pry up the keyboard.
  10. Acer TravelMate P653-V-6882 Keyboard Replacement: paso 10, imagen 1 de 1
    • Slide the keyboard forward to access the keyboard cable.
    • Flip the connector latch up to open it.
    • Pull out the keyboard cable gently.
    • Be careful not to damage the connector.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 430
