Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Device Won't Turn On
Device does not power on when power button is held down
Defective Power Adapter
Plug the charger into the power adapter and try to boot the computer. If the computer still does not turn on, check to see if the charging light is illuminated on the computer. If the light is not on, it is likely that the power adapter is defective. For the battery to charge, the adapter may need to be replaced.
Inadequate RAM
Hardware inside of the laptop may have failed, causing the laptop to be unable to boot. This generally would be caused by insufficient RAM, which may need to be replaced. Since the RAM is integrated into the motherboard, the RAM needs to be replaced by a computer professional or the motherboard can be replaced using this guide.
Device Screen is Unresponsive
User input is not reflected on the screen
Reset the Computer
If the device screen becomes frozen or otherwise unresponsive, try resetting the computer by holding down the power button until the computer shuts off and then turning the computer back on by holding down the power button.
Ensure the Display Settings are Correct
The display may be on the incorrect setting. To switch the display mode, hold down 'Fn' and press 'E' simultaneously. This will switch the display setting back to a normal display setting on the laptop. If this does not fix the issue, hold down the Windows key and press the 'P' key twice. The laptop may have been accidentally set to projector mode, and this will switch it back to computer mode.
Device Won't Charge
The battery of the device will not charge while the device is plugged in
Check the Connector
If the connection from the power adapter to the laptop is wobbly or otherwise not secure, the connector may be damaged which will prevent the laptop from charging. Repair to the connector may be necessary.
Defective Battery
If the laptop does not turn on, ensure that the laptop is plugged in. If the laptop only turns on when plugged in and turns off immediately upon the charger being disconnected regardless of charging time, the battery is likely defective and may need to be replaced. See the guide here for instructions on how to replace the battery.
Distorted Audio Through Headphones
While the headphones are plugged into the audio jack, audio is distorted or muffled
Loose Audio Jack
Through repeated use, the audio jack may have become loose. Ensure that the headphones are plugged all the way in. If the audio continues to be distorted, the jack itself may be damaged and need to be replaced.
Outdated Audio Driver
The audio driver on the laptop may be outdated and may need to be updated. Download the most recent audio driver from the manufacturer's support website.
Device Fan is Loud
The device makes exceedingly loud noise while powered on
Device is Overheating
The fan may be loud because the device is overheating due to dust clogging the fans. Use compressed air on the vents and fans in order to clear out dust that may be affecting fan performance.
A fan has failed
A fan inside of the laptop may have stopped working which causes another fan to work harder and make much more noise. If this has happened, the faulty fan may need to be replaced. See how to replace the fan using this guide.
Un comentario
Loud fan can also be achieved by just wearing out the fan’s bearing, then it would sound like a motorcycle
So check that also if you have a loud creaking fan
andrewsha.levitskiy - Contestar
