Saltar al contenido principal
Acer Aspire S7-392-6484 Battery Replacement
Qué necesitas
  1. Acer Aspire S7-392-6484 Battery Replacement, Battery: paso 1, imagen 1 de 2 Acer Aspire S7-392-6484 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
    • Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
    • After all marked screws have been removed, lift up back panel to expose internal parts.
  2. Acer Aspire S7-392-6484 Battery Replacement: paso 2, imagen 1 de 1
    • Unscrew the marked 1.5 mm screws with a Phillips #01 screwdriver.
  3. Acer Aspire S7-392-6484 Battery Replacement: paso 3, imagen 1 de 1
    • Disconnect the cable located at the top of the battery. Be careful to pull the cable horizontally, not vertically.
  4. Acer Aspire S7-392-6484 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the battery.
Conclusión
Una persona más ha completado esta guía.
Nicholas Wise
Miembro Desde 02/14/18
754 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S2-G6, Eyestone Spring 2018 Miembro de USF Tampa, Team S2-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S2G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 5,484
