13 inch 2011 speaker replacement
Mi Problema
The subwoofer stopped working,I think that it might have been my fault-I played music for about 3 hours with VLC .The sound was amplified at 200%,there was no distortion,but it killed it.
Mi SoluciĆ³n
It took me about an hour to replace both.The screws are very small,an you have to be carefull with cable routing,when you put it back together.Also when I detached the speaker,the metalic plate underneath it moved-you need to hold it in place.
It works just as good as the original.Nice replacement
Mi Consejo
magnetic screwdriver helps a lot with the small screws
0 comentarios
