Replacing 2nd hard drive in 2008 Macbook 13"
seliades -
Mi Problema
I had replaced the main HDD in my Macbook with an SSD and used a data doubler kit to replace the optical drive with the original 250GB disk that came with the Macbook to use as a Data disk with the SSD doing system drive duties. The 250GB disk was full so needed replacement with something bigger.
Mi SoluciĆ³n
The repair was amazingly easy. As I had opened the Macbook before it was easy to get into. Removed the back cover and then 6 screws that held the data doubler. HDD replaced and everything put back together. SuperDuper worked very easily in cloning the drives using the provided USB enclosure.
Mi Consejo
Clone the drive before putting it in.
0 comentarios
