Mi Problema
Needed more hard drive room
Mi SoluciĆ³n
Your repair/install kit was really quite good. Had all the parts necessary. The opening handout with instructions for the external FW enclosure was perfect. Easy to follow and right to the point.
And the visual instructions for the replacement were pretty good. The only things I'd change were...
Mi Consejo
The section on step 11... removal of the ribbon cable that's taped and glued to the old hard drive. That was scary. Couldn't tell how far you could bend the cable and the connection in the lower right corner near the IR was worrisome. I think a couple of close-up pictures of those small steps would be helpful. And another, maybe silly thought is that it would be nice if your tool kit labeled the slots on the outside as to the sizes of the bits. I realize that's a silly thought, in that each bit is labeled once you get it out, but that can be time consuming.
Otherwise, Easy Peasy.
0 comentarios
