Saltar al contenido principal
El Nexus S es un teléfono inteligente desarrollado conjuntamente por Google y Samsung fue el primer teléfono inteligente en utilizar el sistema operativo Android 2.3 "Gingerbread".
My Home Button Touch key doesnt work
Hello guys
It think its the navigation Touch key. Or do you know how I can fix this issue?
How can I replace the Front navigation Touch Key?
Thanks for helping me if this problem
Mark
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
5 Respuestas
Solución Elegida
this is the part this shows how to fit it. If the other buttons and touch screen are working this may solve the problem and is cheap and easy to do.
Fue útil esta respuesta?
Puntuación 1
Unfortunately, the capacitive touch buttons are part of the front panel display assembly. You would have to replace the entire front panel display assembly. Aside from a hardware issue, it could also be a software issue. Is your phone stock or is it running a custom ROM?
Puntuación 0
Thanks for the quick replies. Yes i run the stock rom the Touchscreen and the other buttons are working!
I will try to solve it with this replacement.
Puntuación 0
So the parts finally arrived. I replaced the part and now the screen dont show anything.
At the begining I plugged the phone to power. It showed me the Loading Sign for 2 seconds. Now there isnt nothing on the screen. Did I forget something or did I destroyed something...?
Puntuación 0
My google nexus phone soft key home and recent application key was not working from last two days if any one help me to fix that problem?
Puntuación 0
Añadir tu respuesta
Marc Burkhalter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 2,749
