button to take picture not working.
everything works on my camera except the picture button that you push to process the pictures
Es esta una buena pregunta?
Nicoli, the only way to determine what is going on, is by disassembling your camera.It is possible that it is the actual mechanical button that is not working, or the power switch block PCB that is not functioning. If you disassemble your camera, you could check the switch on the PCB with a multimeter. Check the guides on here to disassemble your camera. Hope this helps, good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 585
