PS2 won't turn on, not even the pilot, there's power
Greetings!
My PS2 won't turn on, it has power (8.58V even on the turn on/off) button, but not even the pilot will turn on! What could be the problem? How can I fix it?
Es esta una buena pregunta?
Greetings!
Hi!
Could be multiple things.
First, did you replaced The power adapter? Would try
That first.
Otherwise it’s most likely motherboard related… please check first if you can try with a new power button with cable. Otherwise you do need to check the motherboard. Sometimes the power jack fails on the motherboard.
Fue útil esta respuesta?
I mentioned there's power trough all the motherboard, so I don't think it's motherboard related, it can't be the power jack or the power adapter
If the motherboard got everything, please check the power button and it’s cable. Could be such simple as that. Thank you :)!
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 85
