Saltar al contenido principal
La línea actual de iPod Touch comprende siete (7) generaciones diferentes.
Preguntas 20 Ver todo
iPod is disabled connect to itunes
ipod is diabled connect to itunes. forgot password.
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Solución Elegida
Linda Rhodes, try this "you can unlock it putting the device into DFU mode and then restore it with iTunes, BUT this will erase all data on your iPod. Here is an excellent description how to place your iPod in DFU mode. The other thing you can follow is what Apple says "If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons." Now there is a way to erase the password but I am not sure if this would work when you are already disabled. This will not erase any data on your device. I guess you can always try and hope you have a windows computer :-) anyhow you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked. Remove your iPod and it will be cleared" The other thing you can do, is to plug your iPod in the computer that you normal use for it and see if it can be restored that way. Hope this helps, good Luck.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Linda Rhodes estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 483
