Compressor doesn't start?
Give the replacement motor part number which isn't listed. But the motor is shown. Thanks 👍 😊
Es esta una buena pregunta?
On the diagram this
would be a pressure switch. That would be the second thing to check after the on/off switch. You should be able to see resistance on the 2 terminals of the power plug with the on/off switch on. If not, short out the pressure switch and see if resistance shows - it should be relatively low, 1-5Ω.
If there is no reading then you might have a bad motor. Try reading directly on the motor leads.
BAsically.
Troubleshooting the Motor:
If the motor doesn't start, common checks include:
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 57
