Saltar al contenido principal
Información de reparación y desmontaje del ratón inalámbrico ergonómico MX Vertical de Logitech. Lanzado en 2018 e identificado por el número de modelo M-R0074.
Is it possible to replace MX Vertical rubber pads?
I have been using the MX Vertical for over 5 years now. For some time, the rubber pads around the mouse has become sticky and worn out. I tried to clean it following the procedures from Logitech website, but it is not really effective. As everything else in the mouse is good, I would like to replace the parts with a new rubber pad, but cannot find any sort of guide for it. Does anyone have a similar issue? What have you done to overcome it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
THAT "rubber" is sprayed on - don't think it is even rubber. Once it becomes sticky it doesn't clean. I have removed that stuff from other things using 90%+ ISO. The plastic below it isn't sticky.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Hermann Simon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 44
Todo El Tiempo: 55
