My parking lights will not shut off
Hello
My parking lights came on randomly and now will not turn off. Any ideas?
I was going to pull the fuse but an actual way to fix it may be more helpful.
Best
sara
Es esta una buena pregunta?
Hello
Best
sara
The Body Control Module (BCM) controls the operation of various electrical units installed on the vehicle. As I always recommend with computer controlled cars, have the computer memory checked for Diagnostic Trouble Codes first, before spending a lot of time checking or replacing parts.
SYSTEMS CONTROLLED BY BCM DIRECTLY
Power door lock system.
Remote keyless entry system.
Power window system.
Sunroof system.
Room lamp timer.
Key reminder
Warning chime
Turn signal and hazard warning lamps
NOTE: Power supply only. No system control.
SYSTEMS CONTROLLED INDIRECTLY BY BCM
Headlamp, tail lamp, fog lamp, auto light system
Wiper
Front washer
Rear window defogger
Fue útil esta respuesta?
Thank you sir. :)
Sara, why did you downvote this answer?
Hi there
I am not sure what that means. Did I click something wrong? Tell me how to fix it and I will be happy to help you out.
SaraAltima, if you look at HemiBill avatar, just above you see the number 4. To the left of it are two arrows. An Up and a Down arrow. If you click the up arrow, the person, in your case HemiBill, receives points for a good answer. If you hit the down button, points will be deducted from his "account" (no money involved, points are the only reward we are getting:) Down votes are usually reserved for blatantly wrong answers or malicious answers.
It's changed now ;-)
I have my middle brake light out and passenger tail light out , I replaced both new bulbs u name it nothing. Even with the driver tail light having operable ruining light the brake feature does not work . I replaced brake and cruise control switch and now have no brake light n no cruise control
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 20,072
5 comentarios
SaraAltima, any daytime running lights on your vehicle or anything like that?
- de oldturkey03
Nope. :(
- de SaraAltima
Yes, I am a newbie to this site and can always use another T shirt! :-) Thank you everyone!
- de HemiBill
OK It's Friday night on a long weekend and I need to sleep.
I won't be able to see a mechanic until Tuesday.
How do I disconnect them?
Please and thank you for any assistance
- de Wolfgang Werner
I went to the junkyard and got a replacement fuise box the one under the hood next to the windshield fluid box and problem resolved it only cost me 15 bucks
- de Eddy
