Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Segunda generación de iPhone. Modelo A1241 / 8 o 16 GB de capacidad / plástico negro o blanco de nuevo. La reparación es más sencilla que el primer iPhone. Requiere destornilladores, curvas y herramientas de succión.
No Backlight
i need help on how to get back the light on my iphone it is very dark and i know it is the backlight problem but i need help to know how to fix it im scared to open it apart and miss the whole thing up!!!! please help!!
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Hi Layla. It seems you might need to replace the Display Assembly. Feel free to use our guide and let us know if you need any help. Best of luck!
Imagen de Replace a scratched or cracked front glass panel or a malfunctioning display for your iPhone.
Producto
iPhone 3G Display Assembly
$59.99
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Although replacing the entire display assembly is undoubtedly the easiest solution, particularly for the less tech inclined, it may not actually fix the issue. Replacing the components responsible for this function is likely to be what's required. But, it does entail desoldering and soldering of 1 or both components on the mother board. See this source, it provides a great zoom pix of component location http://www.amazon.com/CyberDoc-LLC-iPhon.... You can buy both components very reasonably or separately from a NYC vendor.
- de
Añadir tu respuesta
layla ahmed estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 987
